Data access
short5
Can't access my data, have an Acer liquid zest t06 , have gone through all settings but no luck
8 REPLIES 8
JuniorJunior
Have you checked if you have data used or date available??
JuniorJunior
short5
All good, got help from a tech at London Drugs and he input the correct settings , thanks
MJ23
Have you verified that the cellular option is activated? If not, deactivate and reactivate as this can help.
Also try restarting your phone.
if this doesn’t help, please contact a mod.
Thank you,
MJ23
GreatCanadian
Yep, I asked about text and calls working just to determine if his phone works at all. I BELIEVE that phone is compatible with Public Mobile network. Chances are it's APN settings or data not turned on as @NDesai says.
GC
NDesai
@short5 No data usually has to do with incorrect APN settings or data is not turned on.
Post a screenshot of the APN settings so we can see if that is correctly set up.
Alex888
Look under Network Setting and make sure it doesn't say 2G only, all PM data uses 4 LTE, if you have 3G in your plan it is actually throttled 4 LTE.
GreatCanadian
Calling and texting working?
