Data Settings
tarnyc
Seems like a common problem, unfortunately I'm having difficulty with the data setup as well.
I ported my number over from koodo. Calls and texts are working. I've set up my data according to the guide. Here are my data settings;
APN: sp.mb.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: not set
APN type: not set
Extra settings on my phone...
APN protocol: IPv4
APN roaming protocol: IPv4
APN enabled
Bearer: unspecified
MVNO type: GID
MVNO value: 4DF4
Any ideas?
10 REPLIES 10
Rockdaddy22
@anika1105 wrote:
Hello
Im new to PM. I am using a temp. unlocked iphone 5 till I an unlock my own iphone 6. Right now my sim is active but im getting the data error message  'not subcribed to cellular data services'.
I tried to follow the steps but all i have ont he screen is apn, username and password. can someone help please? @Shazia_K @CS_Agent
Have you tried the sim in any other unlocked phone? If so, what happens? Have you tried a hard reset of the device, hold down the home and power button until the  logo appears. Go to general and about and make sure you’re on the latest carrier update 30.0 on my iPhone anyway.  You could also try this if you believe it’s an apn issue
http://www.unlockit.co.nz/unlockit/
srlawren
@Luddite, @Rockdaddy22 any help here?
anika1105
Hello
Janterry
Thank you SO much for these instructions...it worked perfectly when my husband had trouble using data roaming on his new Sony Xperia Z5 Premium.
@tarnyc,
Glad to read that your issue was easily resolved.
Welcome to Public Mobile and enjoy your LTE data !
tarnyc
@Cyber it worked! Seems like I have to create my own Public Mobile APN following the instructions you provided, rather than using the one that the phone automatically finds, even though the values are exactly the same. Very strange indeed!
Cyber
@tarnyc,
Once your APN are configured, do not forget to turn on "Mobile Data".
@tarnyc,
Reset your APN settings to default.
You need to configure your APN Setting to access DATA (internet) and MMS.
Step-by-step APN configuration :
Lithium-OrangeBullet-Jan23-00.jpgStep 1
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
Lithium-OrangeBullet-Jan23-00.jpgStep 2
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
Lithium-OrangeBullet-Jan23-00.jpgStep 3
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
tarnyc
It's an LG Optimus 4x HD P880, Android 4.4.4
DK
What type of phone are you using?
