01-03-2017 02:41 PM - edited 01-05-2022 01:29 AM
Hey
im from Quebec and if i want to travel to Ontario, can I use the Data in the province of Ontario? The data is covered wide-canada?
02-14-2017 03:31 PM
01-03-2017 11:33 PM
Province-wide calling don't mean you are limited to your "home" province. Doesn't matter where you from. For example, if you travel to Ontario, you have access to Ontario-wide calling.
FYI: http://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/What-is-Province-wide-calling/td-p/2404
01-03-2017 04:12 PM
01-03-2017 04:00 PM
This is interesting - to clarify, since I have a province-wide calling plan with data, would I be able to use data Canada-wide?
As I type this, it makes sense that it would, but I am still skeptical ![]()
01-03-2017 02:43 PM
YES ... data coverage is Canada Wide.
