Data Allowance
Marto
I received a notification from Public Mobile that 76% of my data allowance was used. On checking my usage history I find that only 20% is used.
1 REPLY 1
Sansan
Updates are made usually after midnight for the daily usage.  So if you know you  haven't used what it says,  don't worry about the text messages ignore it.
If you want to verify it you can open a ticket at the orange bubble at your lower end of your screen to inquire.
