06-03-2018 11:12 AM - edited 01-05-2022 04:51 AM
Hi community
I would like to know if anyone knows about public mobile coverage in Antigonish Novascotia
Also can I pass from koodoo operator to public mobile keeping the same number.
Thanks a lot
Service
06-03-2018 12:02 PM
@prinzgill Don't forget to give a friend on PM as a referral so they can save $1/30 days.
https://productioncommunity.publicmobile.ca/t5/Rewards/Refer-a-Friend-Reward/m-p/411#M4
06-03-2018 11:35 AM - edited 06-03-2018 11:35 AM
@prinzgill wrote:Thanku very much
Just ordered a sim to try them seems like they are cheaper than others.
If there is a Walmart near you, you can get a free SIM and a $20 credit:
Get a SIM + $20 bill credit when you activate a Talk + Text plan at Walmart!
06-03-2018 11:26 AM
Thanku very much
06-03-2018 11:22 AM
Thanku for quick reply
06-03-2018 11:21 AM
Thanks a lot
06-03-2018 11:18 AM - edited 06-03-2018 11:21 AM
@prinzgill wrote:Hi community
Thanks a lot
It's looks like most of Antigonish is covered, but not all of it:
Although on the coverage map, there is a note:
Coverage areas are approximate. Actual coverage and network services can vary and are subject to change.
06-03-2018 11:14 AM - edited 06-03-2018 11:15 AM
@prinzgill You can have a look at this coverage website but as far as I know it's same network with Telus & Koodo so no zones https://publicmobile.ca/en/bc/coverage
06-03-2018 11:14 AM
If you are on Koodo or telus the coverage at PM will be the same.
yes you can port your koodo number to PM no problems (if prepaid you need to get mods to port for you)
also reccomed getting a temp number first with PM then port koodo number once your PM account is working
