03-25-2021 11:44 AM - edited 01-06-2022 02:22 AM
Hi all, I'm possibly planning a trip from Montreal to Smiths Falls and I was wondering what the coverage is like there? I'd be relying on my phone/google maps to get me there, and obviously need my phone while I'm there.
Will I be OK the entire way there and in that area?
Cheers!
03-25-2021 01:18 PM
@katiefleming :Another option for downloading offline maps is Open Street Maps apps like OsmAnd~ from F-Droid free and open software store.
Also, since many above replies have confirmed coverage to Smith Falls, you should choose one of the replies above as your accepted solution by clicking on the accepted solution button on the post that helped you most - doing so will help others in future who want to know about coverage to Smith Falls too.
03-25-2021 12:46 PM
All great replies, thanks so much! And yes, it's a trip for me when I never get to go anywhere, especially during Covid haha 😄 Cheers!
03-25-2021 12:07 PM - edited 03-25-2021 12:53 PM
Yes you will be fine.
I'd recommend downloading "offline" maps of the area via google maps so you can save your phone's data and won't have to worry at all about cellular coverage while navigating.
I use offline maps and they've NEVER failed me in Canada or the USA - you just have to make sure to download the geographical boundaries of the areas you'll be navigating in/through.
Here's how:
Download areas and navigate offline - Google Maps Help
Happy travels!! 😷
03-25-2021 12:06 PM - edited 03-25-2021 12:08 PM
Trip?! It's not even 3 hours. That's just going for a drive for a visit. Heck...probably doable in one shot in an EV 🙂
As shown on the map, there appears to be solid cell all the way. How could there not be with the population density and geography.
Sigh...whatever happened to looking at a map (on-screen map is fine) and then seeing where you have to turn right at Albuquerque (Maitland). 🙂
03-25-2021 11:58 AM
@katiefleming Can confirm Ottawa to Smith Falls is fine. Have not driven Ottawa - Montreal
03-25-2021 11:52 AM - edited 03-25-2021 11:53 AM
Save your phone and buy a second hand Garmin GPS. As so many vehicles now have them built in, there are lots of good ones for sale. Buy the right tool for the right job.
03-25-2021 11:50 AM - edited 03-25-2021 11:51 AM
@katiefleming wrote:Hi all, I'm possibly planning a trip from Montreal to Smiths Falls and I was wondering what the coverage is like there? I'd be relying on my phone/google maps to get me there, and obviously need my phone while I'm there.
Cheers!
Hello @katiefleming, I do not know personally, but here is the coverage map:
https://www.publicmobile.ca/en/on/coverage
See also:
https://www.telus.com/en/bc/mobility/network/coverage-map
PM uses both Bell and Telus towers.
