07-03-2017 03:03 PM - edited 01-04-2022 02:16 PM
09-03-2018 10:28 PM
I missed all these convos last year and have been suffering w/o text data. Issue hasn't been solved unfortunately.
Wish it could be.
07-04-2017 12:36 AM - edited 07-04-2017 12:38 AM
@Samianauman wrote:
More likely missing lte frequencies.
Check your phone and model on willmyphonework.net.
It's will provide you full spec details and you will find out if its gonna work on lte network on public mobile.
OP said that calls and texts worked. If the phone was missing the required frequencies for voice (850, 1900MHz UMTS), neither would be working at all. Data also works fine on those frequencies. So at the very least he/she would be able to use data on those frequencies in HSPA mode at the very least.
As discussed earlier, the access point settings need to be corrected.
07-03-2017 07:11 PM
Glad to hear it works another happy dude with PM
07-03-2017 04:59 PM - edited 07-03-2017 05:00 PM
@Wonder_why wrote:You will need to input the following information:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
I suggest puting default,supl,mms in the APN type field instead of leaving it blank. Of course, once this new APN is created, make sure that it is selected as the active APN.
07-03-2017 04:48 PM
07-03-2017 03:15 PM
didnt fint taht model on will my phone work but googled it and it says:
Supported Cellular Networks | GSM850, GSM900, GSM1800, GSM1900, UMTS1900 (B2), UMTS1700/2100 (B4), UMTS850 (B5), LTE1900 (B2), LTE1700/2100 (B4), LTE2600 (B7), LTE700 (B12) |
Telus is 1700 and 1900 i believe so it should work
07-03-2017 03:12 PM
Android
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
07-03-2017 03:08 PM - edited 07-03-2017 03:09 PM
07-03-2017 03:08 PM - edited 07-03-2017 03:08 PM
silly question but did you set up your apn settings?
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
