Continental US usage
thapager
Would anyone know if I had service set up before I go to the US, I was thinking the $20 unlimited provincial calling, if I put on the $8 US calling for 10 days at a time, would that work?
2 REPLIES 2
hairbag1
If you're there longer than 10 days, it's simple to re-up the add-on while in USA too.
NDesai
@thapager Yes, you can add the US add-ons before going to the US. Make sure to follow the 2 step process (1. add funds 2. Purchase add-on) if you currently do not have any balance in your account. Once you add the add-on to your account, you will not be able to add the same add-on again until 10 days fully expire.
