09-17-2017 01:15 AM - edited 01-04-2022 02:38 PM
Hello
Just want to clarify something for the Community Rewards...Once you start to earn some dollar rewards for contributing, does it apply permanently to your monthly rewards ongoing, or is it on a month by month basis, like you would have to contribute every month if you want to save some extra dollars?
Thanks
Ben
09-17-2017 12:23 PM
The main thing is to help when you can and when it's most appropriate. There is no set formula for the amount of reward. Help out and let the system do the rewarding.
09-17-2017 11:48 AM
Unfortunately month to month so you will have to stay active. There are guys on here 24/7 and they get the most refund. Personally not worth it to me but maybe best would be to try and get top 5% for $4 off per month.
09-17-2017 06:38 AM
Yes it's month to month you can get upto 6 dollars per month. It a says 10 dollar max per month but 10 dollars can only achieved by Oracle.
09-17-2017 02:14 AM
Monthly
the more active/helpful you're, the bigger reward you get.
09-17-2017 01:32 AM - edited 09-17-2017 01:34 AM
Community Rewards are month to month basis. If you get it for multiple months, they pile up in your account.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
