Checking Your Usage
Rubymangal
Hi,
I am new to the community and wanted to know how I can check my call, text and data usage? Hope someone can help guide me.
Thanks!
Rose25
Hi, you can go to the public mobile website and go to the my account option. There you will be able to see all your account details, your plan details and how much usage has been done.
@Rubymangal wrote:
Hi,
Thanks!
Go to selfserve.publicmobile.ca and log into your acccount. on the left hand side, there is section called My Data & Add-ons.  Click on "View My Usage".
RossN
@Rubymangal hi if you go into your self serve under data and add ons you can check it there also there is a view my usage section
