Charge after switching
Rachelwmin
I switched from Public Mobile to Koodoo before my public mobile plan expired. However I was still charged by Public Mobile. I cannot have access to my previous Public Mobile Self-Serve account so I cannot check why I was still charged for. Please advise.
2 REPLIES 2
will13am
@Rachelwmin, by chance did you use auto pay when you were with Public Mobile and also did you remove the feature before porting out?  If not there is a chance this is why you were charged.  A few customers have reported this in the past.  Anyway, you will need to reach out to the moderator team to fix the errant charge.
All you can do now is message the mods.
No point in saying what you shoulda done 🙂
Send ONE (1) private message to them here and include your phone number and PIN to minimize back and forth identity verification delays.
Forget your PIN? Then you'll need 3 of either of these pieces of information you used when you signed up: full address, birthdate, last 4 digits of CC you might have used, email address on the account, alternative phone number you might've entered when you signed up. Or, in addition, either of these to get to 3: last payment amount and date, last add-on bought and date.
And of course your question/problem.
Then hopefully they will get back to you as soon as they can between M-F 9-9 (ET) and Sat-Sun 9-7:30 (ET). But it could be up to a couple days.
Depending on your notification settings, you would get an email notifying you of a reply. Get back here and see a red blob over the little envelope in the upper right of your screen and click on it to see the message.
