Changing email address
Hollinger
If I change the email address in my account, do I then use it to log-in going forward?
If so, do I also change the password at the same time so they are synced?
@Hollinger wrote:
@LitlLdy
Thanks for your reply. To clarify, by current password do you mean the one tied to the original email address? I don't need to make a new password to go with the new email address?
@Hollinger , the current password that you are using now to sign into your Public Mobile account.
Unless you want to change the password!
Edit: Please come back & let me know how it goes.
Hollinger
@LitlLdy
LitlLdy
Yes, after changing your email address on your account you login using that & your current password. 🙂
