06-26-2017 04:52 PM - edited 01-04-2022 02:13 PM
I'm currently near the end of my three month plan and I like my choices so far. I was wondering if I were to continue with this plan but change my phone number about 2 months in, would I still be on the same plan? Or would I have to make a new plan for a new phone number.
Thanks!
06-26-2017 06:43 PM
wrote:Awesome! Do you know how long the change would take?
Number change should be instant, but port in takes a few hours depending on where you are porting from.
06-26-2017 06:22 PM - edited 06-26-2017 06:22 PM
06-26-2017 05:36 PM
@WearySky wrote:Yup, you can change your number as much as you want (caveat: limited to 1 number change per 30 days, I think? Or that might only be one port-in allowed per 30 days).
Yes, one number change or port in per 30 days.
06-26-2017 05:14 PM
Just bear in mind - you'll lose your existing number if you change to a new number.
06-26-2017 04:54 PM
you are allowed to change your number and keep your current plan.
