10-27-2017 05:52 PM - edited 01-04-2022 02:49 PM
I set my plan to change to the 3GB+1GB Bonus plan last month which renewed on October 25th this month and shows up successfully in the account.
However I got a message that said I've used 75% of the data this month the day after renewal which is just not possible. I checked my account and under Data it says "Amount Used" and only shows that I have some Data left from an Add On I had purchased awhile ago.
There is absolutely no way I've used 4GB in one day. I checked my phone's data tracker and from October 15th until today I've used around 600MB.
I routinely check my data usage to ensure I don't go over, both using the Public Movile self serve account tracking and my phone and sometimes there is a little discreptency between what my phone is telling me, and what PM says I have actually used but never has it missed over 3GB worth of data.
So what gives?
10-27-2017 08:15 PM
@fiver360 as @will13am noted, there is a known issue affecting renewals of some accounts with a 3G data plan (such as my test account, as well as @imm1304's). Contact the moderator team using the link @ShawnC13 supplied above, and they can reset your data for you manually.
10-27-2017 07:49 PM
Apparently there's been issues on some 3G speed accounts with the data meter not resetting on renewal. The moderator team should be able to remedy the situation.
10-27-2017 06:47 PM
2+2gb 3G Speed Data?
Looks like there's an issue with the data, best to msg a moderator and have them look into your account.
Just a little tip, you can easily change the date on your android for your billing cycle to the 25th instead of the 15th, will help you keep track easier!
10-27-2017 05:59 PM
