06-02-2015 09:05 PM - edited 01-04-2022 01:35 PM
Hi,
I am living currently in Montreal and will be moving in June to Kingston, Ontario. I am on the $25 talk and text plan and want to know roughly how long it takes, using the self-serve option, to change my phone number to a Kingston one. Does it take an hour or 6 hours or a day or two to have the change become active?
06-03-2015 11:02 AM
06-02-2015 11:24 PM
Thanks chukdefatey.
Appreciate the tip.
06-02-2015 11:21 PM
06-02-2015 09:26 PM
Thanks again for the reply. I knew the place where to change it. Was merely wondering how long the delay would be from the time of going through that procedure. Cheers.
06-02-2015 09:24 PM - edited 06-02-2015 09:26 PM
You're welcome !
You can change your phone number from your self serve account here.
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/msisdn-swap/
06-02-2015 09:18 PM
Thank you very much for the reply Cyber.
06-02-2015 09:17 PM
