Cellular settings on iphone 7
Raejaques
The instructions are to change the cellular settings but the phone appears to be working without doing that and public mobile shows as provider. Do I need to do anything or just go on my merry way?
7 REPLIES 7
Kim1971kim
You should be good to go 🙂
will13am
Welcome to Public Mobile.
PAULRANG18
Keep on rollin down the highway!
Raejaques
Thank you! All good so far!
geopublic
@Raejaques  If it works then there isn't a need to do anything else. Welcome to PM.
RobertQc
@Raejaques  If everything is working, don't change anything 🙂
Lowufo
I did not need to make any changes on my iPhone 6
