Cel Phone
05-24-2023
11:19 PM
05-24-2023
11:22 PM
computergeek541
Public Mobile tells my husband that he has no minutes left when he makes a call. This has never happened before and he hardly ever uses his phone, once when he did use it extensefully it did not reply that he had no minutes left and had to purchase more.
Service
05-25-2023 12:48 AM
The old website had a detailed list showing the minutes used per each call (after the new website/app rollout, I'm not sure, to be honest). Also, android shows the lengths of your calls as well. Unsure about iPhones, but I'm guessing they also do. I would check that first to see if they match your plan minutes.
05-24-2023 11:21 PM
@Pewee1 wrote:Public Mobile tells my husband that he has no minutes left when he makes a call. This has never happened before and he hardly ever uses his phone, once when he did use it extensefully it did not reply that he had no minutes left and had to purchase more.
Have you husband try dialing a 1 before the area code if that isn't already being done.
