08-20-2020 03:45 PM - edited 01-05-2022 12:50 PM
I can receive texts but cannot send to another Public Mobile user (my wife). Shows that the message was sent but she does not receive it. No problems texting (send & receive) with other carriers for both of us. Checked to see if numbers were blocked or if any info was incorrect, but to no avail. Facing this problem for the past 24 hrs or so.
08-20-2020 04:33 PM
Thanks for all your help. I solved the problem. There was a setting on my phone under her contact info called "Only send SMS and MMS" which was unchecked. I turned that on and now I can send and receive texts from her.
08-20-2020 04:29 PM
Which phone are you an d your wife using?
If one of you is using iPhone and the other is using Android phone, configure iPhone iMessage settings ti enable SMS/MMS. Report result.
08-20-2020 04:08 PM - edited 08-20-2020 04:08 PM
@zawx I would have both of you send text messages to yourselves. This is to see if it's issue with just messages between the two of you or if it's an issue amongst you and all other Public Mobile customers.
08-20-2020 03:52 PM
@zawx , Public Mobile does not block texting activities of any of its users. Check your wife's phone to see if there is any blocks placed on your text. By chance did your wife complete a number port on her account recently?
08-20-2020 03:50 PM - edited 08-20-2020 04:31 PM
@zawx if you were able to text eachother before then try toggling airplane mode on/off and restart your device. also try a network reset. what are the make and model of your phone's?
