12-13-2021 06:16 PM - edited 01-04-2022 04:57 AM
Hi I just switched my account from Telus business to Public Mobile and I am not able to send text messages without wifi. I sent text messages when we were out to my partner and he didn't receive them until we were home back on our wifi.
Also, I have an iphone and cannot send photos or videos to non iphone users
Can you please correct this issue?
Thank you!
K
12-14-2021 10:44 AM
Two options @kparkerhall
1. turn iMessages off.
2. turn data on.
I had same problem with iPhone on PM.
Now I use whatsapp for pictures and videos and non imessage for texting.
12-13-2021 09:15 PM
@CountyDownIeUk wrote:Did you you know that you can share pics and contacts by air drop?
Yup, knew that @CountyDownIeUk
Haven't personally used it, but know about it.
There's likely COUNTLESS other iPhone items that might make my day easier - i'll eventually stumble upon them as well.
12-13-2021 09:10 PM - edited 12-13-2021 09:16 PM
wow....where have you been. I needed that answer years ago. So hold the send until turns green?
I'm not sure if that is genuine or sarcasm... 🤔
Truth be told, @CountyDownIeUk , I only started using an iPhone (first time, ever) 7 months ago as a work device and I had to teach myself all things Apple. I'm a LOOOOONG way from knowing much about iPhones as I've been an Android user forever...
It was actually my offspring who told me about the hold blue message for SMS delivery option. I likely wouldn't have figured that one out myself.
Darn kids - always one upping the folks with these things!!!
A genuine thank you!!! But me, grandpa, will have one to spring on the grand kids and our friends. Sometimes every knows something different but doesn’t share....not intentionally. Can depend on mix of kids friends iPhone vs Android. Our immediate family is all iPhone and most but not all of rest of family and friends are too and I can name the few that are droid lovers.
12-13-2021 09:05 PM
12-13-2021 08:47 PM
This is cool. My iPad can send texts through phone....turned wifi off. iMessage failed. Held finger on blue bubble...and screen choice popped up from bottom....tapped click as text and on its way. Thanks.
12-13-2021 08:32 PM - edited 12-13-2021 09:01 PM
wow....where have you been. I needed that answer years ago. So hold the failed blue bubble with message and send as text?
12-13-2021 06:43 PM - edited 12-13-2021 06:49 PM
@kparkerhall wrote:Hi I just switched my account from Telus business to Public Mobile and I am not able to send text messages without wifi. I sent text messages when we were out to my partner and he didn't receive them until we were home back on our wifi.
Thank you!
K
When sending messages on iPhone, your message may try to send in iMessage format first (the message will be blue in color when you initially tap "send") and you'll notice it is not 'delivered' just to the below, right of the message.
By holding the message you just sent, you can choose to deliver the message as an SMS instead. You'll know it reverted to SMS when the message turns green. You should then see it marked as 'delivered'.
Try this the next time you send a message, the receiver will then receive an SMS text from you.
As far as some users not receiving picture or videos, make sure they have Mobile Data enabled on their device. They then may need to tap on the message to download it.
12-13-2021 06:21 PM
can you do troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
and do Rebooting your phone,
12-13-2021 06:19 PM
Thank you!
K
@kparkerhall - hi there, we are all users and customer just like you, not Public Mobile customer service representatives.
Okay, so check out your settings.
If you turn your data off occasionally, then it is recommended to turn off iMessage altogether and use regular text messaging instead.
To do this, go to Settings > Messages and toggle iMessage off.
If you prefer to use iMessage, then you can perform the following steps to fix the issue:
When starting with a new provider perform a Reset of Network Settings
iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
12-13-2021 06:19 PM
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet Wi-Fi is on is not going through the Picture or a video messaging,
you have to do this to going through you will need to turn your data on to send a Picture or a video messaging in world-wide,
make sure your Data is on.
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
