07-22-2018 02:58 PM - edited 01-04-2022 06:30 PM
Hello,
I have the $10 plan, which includes 50 minutes of Canada-wide calling, but I cannot evven make a call within Ontario. I am getting this message: "Sorry, we cannot complete this call. You don't have an active long distance addon, and this call is not covered by your plan". An help is appreciated!
07-22-2018 03:55 PM
@geminim06, check also that available usage is not consumed. If the suggestion of including 1 in front of the 10 digit number doesn't work, your problem could be due to account provisioning. For that you will need moderator team assistance to correct. The moderator team can be reached via private message using this link. Please include in your private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
07-22-2018 03:44 PM
@geminim06 wrote:Hello,
sound like the system never correctly set your plan up
Usually, when this type of thing happens, it's usally on plans that only include province-wide calling.
It's recommended to dial the 1 before the area code and number. But that will only make it so that you don't hear a "long distance charges may apply" message. Not dialing the 1 wouldn't prevent you from making the call; it would just delay the call a few seconds.
Double check to make sure you're not misdialing the number (ie. the area code).
If you still have no luck, you'll probably have to send the moderators a message to fix this.
07-22-2018 03:42 PM - edited 07-22-2018 03:49 PM
@geminim06 Is it only a few numbers that do not go through or all numbers? Did you try adding 1 in front of a number you are dialing?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
