Cannot make call to some numbers
missorange
I cannot make call to certain number like 1855.., not all number, it looks straightly blocked some phone number. Because I can make call through other phone, just cannot by public mobile?
JL9
Can you send/receive texts?
@missorange
Check to see if there is an Telus outage in your area:
https://istheservicedowncanada.com/status/telus/map
Or if you are on the $15 plan, check your account to see if you have gone over 100 minutes.
@missorange wrote:
The acct is active
That is good @missorange . Are any other services working?
You can try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if this helps with making a call.
missorange
The acct is active
@missorange  - if your account status in self serve is ACTIVE, try to:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • can you try your SIM into another phone to see if calling out works? Does texting in/out work, and data?
mimmo
Can you receive calls?
  Is your account suspended?    When was your renewal date?  Try calling 611 or logging into selfserve? To check status?
