Cannot Send MMS on Flip Phone
Obice
Hello folks
Today I switched from my malfunctioning android to my flip phone for calls/texts and to my dismay and otter exasperation I have run into a problem with my flip phone. Just my luck, perhaps.
I tested receiving MMS to my flip phone however my flip phone gives me a "Failed to respond, Try again?" Message upon sending MMS out. My only guess is that MMS works over 4G/LTE and my flip phone only operates on 3G. But then how can it receive and not send? This is annoying.
I paid for it so it would be great to have it work.
Thanks for any help.
10 REPLIES 10
Obice
@gblackma
Yes, I tried aliasredirect and it caused my phone to restart. I have a spare iPhone might just use it, I just need something to work properly at this point.
@Solo
Moving your SIM card from phone to phone have you endured that the ... aw gee, can’t remember name now...whatchamacallit list (technical term) APN Settings (thank you @Anonymous ) are set correctly in each phone?
AE_Collector
 @Obice
Before what? When?
It's almost certainly APN settings.
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
@Obice Here's a link to someone with the same problem and phone and how they fixed it  https://productioncommunity.publicmobile.ca/t5/Getting-Started/Setting-up-data-connectivity-on-a-Sam.... Let us know if it works. Thanks.
Solo
well my friend I've had the same problem in the last month I've changed phones three times and I couldn't get to use any of my data or anything's a problem that they need to fix if you got a solution please get back to me cheers
@gblackma
Data IS used for MMS, but it is deducted from your data consumption records. So it has to be fully functional.
AE_Collector
JoyLuck
Did you try taking the sim card out and putting it back in?
Obice
It was working before. That's all I do know.
Make: Samsung, Model: SGH-C414.
gblackma
@Obice data isn't used to send mms  text messages. The only requirement is that it be enabled.Try menu- settings - applications - messages - multimedia message - message centre mms - select your version and click activate. Restart your phone and send a mms message. Let us know if it works.  Thanks.
If it doesnt, what's the make and model of your phone? Thanks.
kselmak
It should be working on 3g only
Do you have ways to alert network settings?
What phone do you have?
