07-08-2019 10:56 AM - edited 01-05-2022 08:15 AM
Does public mobile accept amex as autopay?? I tried registering it but it keeps failing
07-08-2019 11:31 AM
Thanks I'll try that solution now
07-08-2019 11:23 AM
Please ensure you're adding the apartment #/Suite # to the Address 1 field in either of the following when leaving the other spot blank:
Apt # - House # StreetName StreetType
-OR-
House# StreetName StreetType Apt #
07-08-2019 11:16 AM
@Pur3aznboi yes unfortunately that happens alot I to ended up using another cc and a day later the one I had trouble with was accepted go figure
07-08-2019 11:12 AM
Thanks I tried doing exactly what you said leaving out my unit number and entering postal code without spaces still getting the same message but I was able to add my visa card so I'll just leave it like that thanks for yiur help
07-08-2019 11:08 AM
Great thx
07-08-2019 11:04 AM
@Pur3aznboi wrote:Does public mobile accept amex as autopay?? I tried registering it but it keeps failing
@Pur3aznboi Yes they do. I'm currently using AMEX without any issues. When entering the postal code don't use a space also if you live in a condo or apartment dont use the unit number. If it's still a problem contact PM and they will add it for you.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-08-2019 11:03 AM - edited 07-08-2019 11:05 AM
@Pur3aznboi Yes PM accepts american and canadian cc people seem to be having a few issues right now maybe wait an hour,
07-08-2019 11:03 AM
Yes, I have 3 PM accounts. 2 of them are using AmEx for autopay.
