03-05-2018 01:59 PM - edited 01-04-2022 03:39 PM
This is probably the sixth time I’ve emailed Public. I have been paying for services I am not receiving. I can make calls and texts but cannot receive them because my chosen number which I was told was available has not been ported. It has been a month and PM does not seem willing/able to assist me.
03-18-2018 02:44 PM - edited 03-18-2018 02:49 PM
@Lawgirlnicwrote:Hi there,
I have now had the number 647-======== assigned to me by Pinger/Text Free.
Could you you please advise how I can now go about having that number properly ported to my Public Mobile account?
Thank you,
Nicol Koteff
Login to your PM account, click Change Number, and follow the directions to Transfer your number.
If you do not have an actual account number from Pinger use your phone number. It may take a few days for the transfer to complete. If there is anything Pinger that requires to port-out your number be sure you have done that before beginning.
This assumes you do have an active PM account.
EDIT: Are you sure Pinger allows you to port-out their number?
03-18-2018 02:21 PM - last edited on 03-18-2018 02:40 PM by Luddite
Hi there,
Thank you,
Nicol Koteff
03-05-2018 02:04 PM - edited 03-05-2018 02:05 PM
@Lawgirlnic, what was your previous method of contact? Public Mobile doesn't have an email contact system. The moderator team can be reached via private message within this community forum. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team. Good luck.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
