05-09-2017 12:27 AM - edited 01-04-2022 01:45 PM
Hi,
I can't log in at https://selfserve.publicmobile.ca/
I'm quite sure I know my password, but I used the "Forgot password" link anyway. Filled out my security question, got the email, set up a new password, and tried to log in again. Still couldn't do it.
Repeated this process two more times. I can change my password no problem, but I just can't log in.
I have two accounts with Public Mobile. The other one I can log in with no problem.
The problematic one -- I have a feeling it has something to do with the fact that I there's a Koodo account using the same email address.
How can I fix this?
05-10-2017 09:33 PM
05-10-2017 09:32 PM
Hi @Pier, that link appears to be broken, but I found the article here: http://productioncommunity.publicmobile.ca/t5/tkb/articleprintpage/tkb-id/knowledge_base/article-id/...
I've contacted a mod. Thank you.
05-09-2017 01:10 AM
05-09-2017 12:44 AM
As mentioned, you may need the help of a moderator. They may get you to do another password reset from their end. Since password resets are time sensitive, and since private messaging is the moderators' preferred method of communication, I recommend you turn on e-mail notifications for receipt of private messages in your community account. To do this, go to Settings -> Preferences -> Private Messenger. There is a checkbox next to "Receive email notifications for new private messages" which you can toggle on/off. Be sure to click save after making the change.
05-09-2017 12:35 AM
Sorry to hear that you can't log into your account. Just send a private message to one of the moderators and you'll get help. A single click on the link below will guide you on how to do that.
Yours,
