10-25-2020 07:26 PM - edited 01-05-2022 03:54 PM
10-25-2020 07:53 PM
I can understand your frustration with this. Can you tell me if you're able to reset your password from this link below:
https://selfserve.publicmobile.ca/forgot-password/
If you're unable to complete that step, then message a mod below:
10-25-2020 07:37 PM
@Joceybear_11 To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Click the bubble comment circle on the bottom right hand side of your screen to talk to SIMON the chat bot or link:
2 - Contact the Moderator_Team via private message using this link:
10-25-2020 07:36 PM - edited 10-25-2020 07:39 PM
@Joceybear_11 wrote:Can't log into my phone requesting immediate moderator help
contact a moderator you can do so by clicking the circle at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue password reset
you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
