05-11-2020 11:24 PM - edited 01-05-2022 10:45 AM
Hello,
I was wondering if I can turn off data daily from 10:30 pm to 8:00 am? I do not want my child to be on the Internet during that time.
Thank you,
Angela
Joining Public
05-13-2020 01:26 PM
I will suggest getting $15/30 days plan for your child and giving access to home wifi for usage at home. You can restrict access by controlling the device usage from your modem.
05-13-2020 01:05 PM
Seems like you can't time it on the plan itself, one option is to take the phone away during that time, but if you forget to do that once, you'll keep forgetting it. The better option would be installing an app that times out network connection or even a screen timeout app.
https://play.google.com/store/apps/details?id=dev.tuantv.android.netblocker
https://play.google.com/store/apps/details?id=io.familytime.dashboard
05-13-2020 11:59 AM
The wifi on the computer turns off at 10 pm. But the cellphone has data that doesn't need wifi. I couldn't find anything in the account to turn off data hence this post. Thank you!! 🙂
05-12-2020 11:17 AM - edited 05-12-2020 11:21 AM
@GenieGirl18 just suspend their whole service, use the "lost and found" in self serve and then just turn it back on in the morning haha. who do they need to call at 10:30pm anyways. just tell them you don't know what's going on... there must be something wrong with public mobile. 😂
05-12-2020 07:46 AM
@GenieGirl18 There are apps that will allow you to do what you want. Check out here for some:
https://thewirecutter.com/reviews/best-apps-to-manage-your-kids-phone/
05-11-2020 11:39 PM - edited 05-11-2020 11:40 PM
@GenieGirl18 you can do this with various apps that you will need to load on your child's device. I have a few kids so I know your dilema. 🙂
Depending on how savy they could figure it out fairly quick though. Although some of these apps like covenant eyes, allow you to block websites and time on the internet and you have to actually call into their call centre to remove the app and you also get an alert if they try to remove the app.
You can check out the website here:
cheers
05-11-2020 11:33 PM
@GenieGirl18 Some phones may have parent control or digital wellbeing. It can protect your child from using data. But it depends on the model of your phone. PM itself can't time your data until you used it up yourself before cycle renews.
05-11-2020 11:33 PM
HI @GenieGirl18
I don't think this is possible under Public Mobile. Data is set for 30 day plans with no interruptions.
05-11-2020 11:31 PM
You will have to rely on your phone to do that
Check if your setting have digital wellness and parental control
There may be apps for there that do that too
05-11-2020 11:31 PM - edited 05-11-2020 11:31 PM
With some routers you can program times the internet will turn off. Some can even do it by device.
05-11-2020 11:28 PM - edited 05-11-2020 11:30 PM
@GenieGirl18 wrote:Hello,
Thank you,
Angela
There is no setting to turn off data in self service. You will have to take his phone away. You can turn cell data off on the phone, but your child might turn it back on again if they know how.
