04-01-2023 08:01 PM
I have unlimited call minutes but can't make or receive calls. I've removed my sim, restarted my phone to no avail
04-01-2023 09:25 PM
Check for an outage in your area on the outage map:
04-01-2023 08:12 PM - edited 04-01-2023 08:13 PM
Try the public mobile SIM card in another device, if available, to rule out whether it’s a device issue or a service issue.
While you’re at it, try the other person’s SIM card in your device to see if their service works using your device.
04-01-2023 08:07 PM
Text not working either. The status is active
04-01-2023 08:03 PM
Or… Have you recently activated here and perhaps did not respond “yes” to the port authorization request from your prior mobile service provider?
04-01-2023 08:02 PM
does your data and texting work?
When you log into self-serve, what does the status display as?
