Call forward to a long distance number
08-16-2018 03:38 PM - edited 01-05-2022 12:33 AM
If I call forward to a long distance number in Canada and I have unlimited calling in Canada, do I pay long distance on the number receiving the calls or would I be charged through my actual number?
Joining Public
08-16-2018 09:46 PM
@therad, you should be fine with doing the call forwarding. One thing to always keep in mind is this is a prepaid service. There is no bill shock. If there is something you want to try to see if your plan allows it, just try it without concerns of bill shock. The worst case is it doesn't work which means the feature is not included in the plan.
08-16-2018 03:51 PM
To add to @stonechucker's reply:
You don't incur overage / extra charges with Public Mobile's prepaid concept - if you haven't paid for a service up-front you don't have access to it.
One way to avoid the uncertainty (or if someone is on a province-wide plan only) is to get a local Fongo number, forward calls to that and use your data to receive the call.
08-16-2018 03:43 PM
I believe you'll be fine, no long distance charges. I've not done it, but it seems to make sense as unlimited Canada-wide calling means no extra charges, and on the unlimited talk plans, forwarding a call is included.
