Call Forwarding
01-31-2018 01:54 AM - edited 01-04-2022 03:25 PM
Hi,
1. When a phone is call forwarded, will text messages be forwarded as well?
2. When call forwarded, are you limited to an amount of minutes?
3. Can voicemail be checked from a landline?
Thanks
Joining Public
01-31-2018 08:59 AM
@mimmo maybe only using conditional call forwarding as an example
So both calls get forwarded and users leave voice mail at Public
wrote:text messages are not forwarded
no limits that i know of
not sure about voicemail, but if it is forwarded then how could someone leave you voicemail
01-31-2018 08:57 AM
1- no txt are not forwarded in same way
2- technically no but even for unlimited minutes Public does have disclaimers about reasonable use. I assume if use for personal purposes there is no issue
3- yes but not easily
01-31-2018 03:36 AM
@KD74. In order to check your voicemail from a landline, just call your cell number, and when you hear your prompt, just hit the * key. You will be prompted for your password, and you are in.
01-31-2018 01:59 AM
wrote:Hi,
Thanks
