CHOOSUNG PLANS
MOALIMBUKHARI
UNLIMITED TALK CANADA WIDE AND UNLIMITED TEXT WORLD WIDE AND DATA HOW MUCH IS THAT MONTHLY AND CAN I KEEP THE NUMBERS THAT I HAVE NOW WITH MOBILICITY.
7 REPLIES 7
Moid_I
Retraité / Retired
Retraité / Retired
@MOALIMBUKHARI Please click on the plans page on publicmobile.ca to find out about all our plans available
Please click here for Plans and yes you can port or bring in your phone number from Moblicity.
Also, if wanting to buy handset, Here's some tips
Telus ONLINE ONLY, Telus Physical Stores Do NOT sell to Non-Clients of Telus outright
Koodo Physical Stores Do, As long as Handset has Purple Label on Them
Rogers, Bell/VM, Wind Physical and Online Stores Do NOT sell to Non-Clients Outright
Fido Physical Stores do, But at great cost: Cost of Handset, + $25 Fee, + Unlock Fee
Wal-Mart, Best Buy: Regular Stock phones are NOT available for Outright purchase, Contractual Clauses between them and Carriers
Only Prepaid selection available for Outright purchase.
If Handset is Telus or Koodo, Most time, no Unlock required because same Co. Owns PM, Koodo and Telus as well as HSPA+4G Network
Also, You can certainly keep your Mobilicity #, Porting is simple. I Must also Point this out too.
New PM Clients have NO, Zero, 0 Access to a Call Center, only Community, Email or private messaging a PM Community Rep Teamster. Response time from community takes less time
Email can take 24-48 HRS, and Not including Weekends
PM is essentially a Buffet-Style Pick/Customize your own Plan and Check-Out
Also, PM is a BYOD, PM does NOT sell Handsets at all
Handsets you bring MUST have 3G Minimum for Service
PM Does NOT Support GSM 2G At all
3G Frequency: 850/1900 MHZ
4G LTE Frequency: 1700/2100 MHZ
TBD 4G LTE Advanced Frequency: 700 MHZ and only Handsets with that Function will work with that
PM uses Telus's HSPA+4G Network, which is Nation-Wide, Unlimited Tk + Txt
Data is NOT Unlimited
Public Mobile is Prepaid, No Overages of any kind
Data: if you gave 1Gig and reach your cap, Data shuts off until Plan is renewed or you Buy a Data Add-On, which Never Expires, but Remains with you until you Use up all the Add-On data and then you Buy More Add-On Data
If you Choose the Canada-Wide Tk+Txt and 4Gig Data, Cost would be $80 after the $15 Discount when bundling 3 Plans together. All PM Plans are Singles only, Like Talk is either Provincial or Canada-Wide
Txt is ONLY Canada-Wide
Data is 1Gig or 4Gig
$10 is for 30 Days of service, which is Not a Plan, just to Start
HI. PM currently has NO International Txt of any kind for New PM Clients, ONLY Canada-Wide Txt
MOALIMBUKHARI
UNLIMITED TALK CANADA WIDE AND UNLIMITED TEXT WORLD WIDE AND DATA HOW MUCH IS THAT MONTHLY AND CAN I KEEP THE NUMBERS THAT I HAVE NOW WITH MOBELICITY.
