Bought the same addon twice accidently
bkim03
I accidently bought the same us roaming addon twice.  Can I get refund the one?
bkim03
Thank you very much!
The mos is already tagged . so you can either wait or send them a private mail.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Contacting-our-Community-Moderators/ta-...
The link will inform you of what you need on how to contact a mod. You should have a response by tomorrow morning
Watoko
As you have already tagged a mod, I suggest you also send a PM (instructions here) as they are off hours right now, and will likely respond in the morning.
Just didn't want your issue to get burried on the forums.
Shutdown
I already tagged for you but you type @ then type name
bkim03
Thanks.  How do I tag the mod?
Shutdown
Tag a mod for issues like this users can't really help @Shazia_K
