11-29-2023 12:36 AM
As the title states, I am flabberghasted as to how to fix this. Seems it has happen a while back as well as I now have 1000 mins for a service I never use (Int'l talk) ...
Help @CS_Agent
I need to exchange the one for the other (Int'l talk mins -> 1GB Data Add-On)
Thank you,
Shane
11-29-2023 12:41 AM
thank you kindly.
11-29-2023 12:38 AM
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
