Best mobile phone signal booster for home use | Expert Review
dhoni4455
 I researched the best mobile phone signal booster for home use over the past few days because I am struggling with weak signals inside my house. I read reviews on TechRadar, Consumer Reports, and a few trusted forums, and they are marking these two as the best:
Amazboost Cell Phone Booster for Home
https://www.amazon.com/Amazboost-Carriers-Verizon-T-Mobile-Approved/dp/B0897MKSKX/?th=1
weBoost Drive Reach Overland
https://www.amazon.com/weBoost-Drive-Reach-Overland-Vehicles/dp/B0BJY35SQ2/?th=1
However, I am having trouble deciding which one would best suit my needs and need your expert advice.In my home, we have multiple smartphones (both Android and iPhone), a Wi-Fi router that sometimes struggles due to low signal, and we also use the phones for video calls and streaming. Some rooms, especially the basement and upstairs, have almost no bars at all.So which one should I buy? Any recommendations or personal experience will be highly appreciated.thanks in advance
edited by computergeek541: changed category labels as this discussion is related to how to use the Community website
2 REPLIES 2
cellphoneuser1
Do you have good signal outside your house?  If you have no or weak signal outside, a signal repeater isn't going to do much.  It doesn't boost singal, but repeats it instead.  These will possibly make the signal go futher into your house,  but a signal that isn't already there can't be repeated. It might make it so that you have signal in more places in your house, but that doesn't always mean that it will be good signal or give good data speeds.
hairbag1
@dhoni4455
what area of Canada do you reside ?
