07-20-2019 12:59 PM - edited 01-05-2022 05:59 AM
How can I access what my average data use per month is?
Is this number already in my profile somewhere?
Or can I view past month records, month by month, and figure it out myself?
thank you
07-20-2019 01:29 PM
Sorry web is call type. May have to click twice to get them on page 1.
@ChuckYeah wrote:Click on the orange heading over data usage or web and it will bring them all together and that should make it easier.
07-20-2019 01:28 PM
You can also check your estimated data usage on your phone.
You can view cellular and wifi usage separately. My wifi usage is absolutely obscene.
07-20-2019 01:25 PM
07-20-2019 01:15 PM - edited 07-20-2019 01:16 PM
07-20-2019 01:14 PM
@thymewalker wrote:thank you - but I don't think I have a self-serve account - or at least I don't see anything that says self serve.
I can see my usage for this month, but no history tab
Upper right of every page...My Account in orange.
Log in or create a new account.
Under the Change plan button click View my usage. Click on Usage Type heading to sort. Look for MB. The column to the left will show the quantity.
07-20-2019 01:12 PM - edited 07-20-2019 01:14 PM
@thymewalker hi you have to create one self serve account it's separate from your sign up
07-20-2019 01:11 PM
sorry found the history -
is there any monthly summary version or just incident by incident of data use?
07-20-2019 01:06 PM
07-20-2019 01:02 PM
@thymewalker There are a few ways you can track your usage. You can track it on your phone in data settings or by installing an app such as Data Witness. Or you can log in to your self-serve account and see the usage counter on the Overview or Usage page.
07-20-2019 01:01 PM
@thymewalker in data and addon section of your self serve it will show what your using this month you also have a history page you can look at
07-20-2019 01:01 PM
@thymewalker wrote:How can I access what my average data use per month is?
thank you
You can see your detailed usage in the self-serve. It requires a bit of manual work though. You can click on the headings on the top of the list to sort by column.
