Available Funds
_markymark
What are my available funds? What does it mean by add funds to my account?
Alexandf
@_markymark
if you have in available funds, you can used for bill payment or buying add-ons.
hairbag1
Available Funds are $$ in your account for next renewal or any add-on purchase you might want to make.
You can add $ $ in preparation for subsequent renewals at anytime before next renewal.
toxicfire
If you dont want to use a credit card on the account for auto pay you can just add funds to your account either by card or purchase prepaid credit at say walmart.Then it just adds those funds to sit on your account.
Also with the reward system once you gain points you can exchange them for account credit and then it would appear in this available funds.
If you refer a friend and get the bonus from that it also goes to this area.
Your Available funds are the dollars you have available to put towards future renewals. The funds will be taken from Available Funds first on renewals after rewards are applied (if on old rewards system).
Adding funds to your account? Just means to add more Available Funds. So if you want to pay for 6 months and set it and forget it, then pay for the next six 30 day renewals (if not on autopay).
