03-03-2020 03:43 PM - edited 01-05-2022 11:03 AM
Hi all,
Hope you can help me with this. When activating my public mobile account/number is choose to do auto pay. To my recollection I set it up right away. Now, my first payment is due tomorrow, I got a text from Public Mobile stating:
"Your payment is due tomorrow & there isnt enough money in your account to renew your plan".
I just want to double check if everybody who is using auto pay get this or should I need to do something?
Thanks for your help in advance!
03-03-2020 04:07 PM
@Toost wrote:Hi all,
You may also see a message in your account as the payment becomes due that your service has been suspended. You can ignore that also. It's just a bug endearing feature of PM.
03-03-2020 03:57 PM
Is this the text you got? If so and you're on Auto-pay don't worry about it.
03-03-2020 03:54 PM
@Toost Is the first message the one you are referring to, see link below? If it is, then it's a standard message. You could also test your autopay today by applying a one time payment of $1. In your self service account. https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Public-Mobile-Thanks-for-paym...
03-03-2020 03:49 PM
@Toost yes, it is fine. If your self-service account says that your Autopay is enabled, you no need to worry. Welcome to PM![]()
03-03-2020 03:48 PM
Did the text message also say "if you have registered for autopay you can ignore the message" To check if you are registered log into your self serve and see if you see aupay discount $2(could be $ if first renewal) listed on the overview page on the left side.
03-03-2020 03:48 PM - edited 03-03-2020 03:48 PM
Hey @Toost
That is just a reminder text about your plan renewal.
If you have autopay set up, Let it do its thing. You can ignore the text
It will automatically take the payment and renew your plan.
Cheers
