AutoPay Due date
Akalirai
Hi I'm on a 3 month auto pay plan. My last payment was Mar 15, and my next payment is due Jun 15. But why does the AutoPay section show there is a one time payment on May 11? What is this for?
Thanks
Amarjit
7 REPLIES 7
@Akalirai wrote:
Hi - see the Available Funds section and the AutoPay section above.
Thanks
@Akalirai The moderator will fix it for you and both dates will show the correct date which in your case is June 15.
Note: Both dates should always be the same!
Akalirai
Thanks
thly6127
Hi, can u post a pic so I can help u out. Thanks
will13am
@Akalirai , I would not worry too much about that date.  It is pretty much for notification only and not actionable.  It is a glitch that Public Mobile is aware of.  I would have thought this maintenance update was to fix known bugs.  Maybe next time.
Akalirai
It does show May 11 as the next payment date and June 15 in another section. June 15 is correct one. I contacted moderator team.
Thanks
geopublic
Thanks
Amarjit
@Akalirai That is a known problem that has been well documented. You need to contact the moderators as suggested and ask them to sync the dates otherwise your billing will get messed up and create bigger headache 4u. Good catch!!
@Akalirai- Any chance you did a manual payment for some reason?  Does the payment appear on your credit card statement?  If you could post a screen shot of your payment history, that might help shed some light on it.  May 11?  Maybe you mean April 11?  If it is a system glitch, you will need to contact the moderator team and ask them to clear it up.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 8AM-Midnight(EST) & Sat/Sun 8AM-10:00PM(EST)
