11-23-2016 01:28 PM - edited 01-04-2022 01:16 PM
Hey guys,
First of all, I searched dozens of thread about tethering not working and none of the proposed solution worked.
My spouse and I can't use tethering since we moved to PM.
My spouse's phone used to be able to tether with Fido with her OnePlus One but now she can't with PM.
I can't tether either with my Google Pixel. Only PM sim cards have ever been inserted in that phone.
We tried tethering to my Chromebook and to her Windows 10 laptop. I also tried to tether to my Windows 7 work laptop.
Could it be a problem with the SIM card?
Wifi tethring and USB tethering isn't working.
Data works on the phone normally.
Here are my APN setting which I found here in the forum.
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
02-02-2017 07:31 PM
Thank you for replying. I guess as long as I have 4G; it is good then. No need to do any change...
02-02-2017 07:06 PM
@kejongliu wrote:
Questions:
1. Why the settings of APNs are different on my phones?
2. Why I don't see LTE but 4G on my phones?
The APNs are set up by the manufactuer in the software of the phone. Different software versions can mean the access points being set up differently.
"4g" is just a marketing term. It could mean LTE or it could mean HSPA. It depends on how the software on the phone has been programmed.
02-02-2017 06:42 PM
I have two lines with PM. One on an international S7 G930FD and one on a leEco Max 2. The S7 has band 4 for LTE and I have to enter the below info. to get "4G" icon on the phone.
APN type: several codes....
MVNO type: GID
MVNO value: 4D4F
The other Max 2 phone, I have to leave them to Empty and None to get 4G.
Questions:
01-17-2017 01:32 AM - edited 01-17-2017 01:41 AM
I know that you already solved your issue but I had a simpler fix that worked for me. I deleted the two separate APN's and manually re-entered as a single APN. Success. (I added "dun" just to be safe)
If this solution also works for you, please bravo to let others know.
11-28-2016 04:23 PM
@Kinnay thank you for posting that! I hope it's helpful to others that are having issue with tethering/hotspotting!
11-27-2016 02:32 AM
Those 2 APN, I was the one who imputed them, GOT Directly from my Handset, so as to provide PM Clientele the info necessary
11-27-2016 01:30 AM
I finally found a fix.
I saw 2 posts here suggesting something similar,
One required root and the other didn't work.
You need to connect your phone and do a command with the adb tool.
adb shell
settings put global tether_dun_required 0
That's is. Wifi and USB tethering now works.
11-23-2016 10:21 PM
11-23-2016 06:55 PM
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN type: internet + mms
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D
Values in bold are are what's different on my setting and teathering works fine on my S7
hope that helps
