04-05-2020 02:03 PM - edited 01-05-2022 10:15 AM
04-05-2020 02:48 PM
You had a problem woth@AshtonM this private message link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-05-2020 02:46 PM
i made account yesterday and upon activation i selected port number and it just caused errors
04-05-2020 02:45 PM
i used that linked and filled in all the info in the ticket and i was not able to submit the ticket at the end
04-05-2020 02:42 PM
@AshtonM While waiting for the moderators, try your Koodo SIM. It should work until the transfer is completed, provided you did not close the account.
If neither Koodo, nor PM, is providing service try out the TextNow app. Free calling/texting while on wifi. The similar service from Fongo is my backup.
04-05-2020 02:10 PM
@AshtonM use this private message link to contact them directly https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Type "Port Request " in the subject field and use this link to see what is required to port your number https://productioncommunity.publicmobile.ca/t5/Announcements/Number-transfer-in-Self-Serve-impacted-...
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there.
You can also enable email notification to receive a private message notification sent to your email.
Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
04-05-2020 02:07 PM
Hi @AshtonM ,
It sometimes takes 24-28 hours for them to get back to you.
They are mostly backed up/low staff due to the COVID.
are you getting up the account right now or you have already created an account with a new number.
Did you choose a new number already and just requesting a port?
Let us know
04-05-2020 02:05 PM - edited 04-05-2020 02:08 PM
@AshtonM wrote:Can someone help I am trying to port my Koodo number to PM and nothing is working.
I cant submit a ticket, Its been 4 hours and the Moderator team has not gotten back to me
Did you use the link below
Check your sent folder (envelope icon) to ensure the message was sent and your inbox for a reply.
To ensure the safety of our team members during the COVID-19 pandemic, our Moderator team is working at reduced levels. During this time, you may experience longer than normal wait times when contacting our Moderator team for help.
