Additional data not working
Jeff6200
I bought additional data. It shows in the app. But I keep getting messages that my data is all used up and the additional data I purchased is not working.
Jeff6200
I will try your suggestions but I still maintain this is a ridiculous quality control issue.  I am in the US for next 2 months. There is nothing to alert an end user that you are purchasing “Canadian” data.  Moreover, my base plan should make it so it doesn’t matter.
@Jeff6200
you have the $25 10GB data, that is Canadian data.  You should be able to use it if you are in Canada.
ask PM to check and reset your account on the system
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
Jeff6200
Here is a screenshot of my purchases. I have the Canada/US/Mexico plan as a base.  There is no indication of any country specific designation to the additional data purchase, even when I check the downloadable invoice
can you confirm on your My Account -> Payment history to see which data add-on you got?  I have a feeling you bought the wrong one, maybe you have got US roaming data instead of Canadian data
Jeff6200
My phone does not have a data limit setting that I can find
I have rebooted several times now
My PM sim is virtual
I strongly feel there is something at the PM end that needs adjusting
slusagm
check if your phone has a data limit enabled, it might be your phone that is blocking the data usage
and try Reboot phone and Reset network settings
also if you can find another phone,  test your sim card there
