Activation
rijylorance
I bought a new sim today and its data is working,but can not make a call
mimmo
What phone are you using? Make sure it has the 3g bands for calling, try will my phone work. Net
Also Disable wifi calling if enabled
oglat
Can you test your sim in a different phone?
geopublic
@rijylorance Does your plan include calling? Check using selfserve to make sure you got the correct plan. Public Mobile users 3G for calling did you make sure your phone is compatible?
GR
You can't call in or out?  How about text messages?
