11-25-2023 02:55 AM
Hello. I am new to Public Mobile and unable to activate the black Friday 5G deal. Using the App to activate keeps looping me back to Login page. I saw an earlier post that there are issues with the App. Hopefully, someone can help provide an update. Thanks.
11-25-2023 09:33 AM
@Meelfong Awesome!! Happy to hear that it ended up working!
11-25-2023 06:12 AM
Hi Andy85,
I think you are correct. It was the App and Black Friday. There was a delay with processing. I received an email confirming my subscription after. In process of transferring number now. Thank you!
11-25-2023 05:59 AM
Thank you for your response sarahuwu. I received an update. See response 2.
11-25-2023 03:09 AM
I had the same issue and had to reinstall the app before it let me log in and install the esim
11-25-2023 03:06 AM
Hi @Meelfong ,
It is likely an issue with the app. The site and app have been dysfunctional today but are slowly beginning to work again. You can try to see if the website gives you more success after clearing your cache and using incognito mode.
If the issue persists tomorrow while all other areas of the site/app are running fine, I would consider opening a ticket:
An agent will send you a message in your community inbox if that's the case so keep an eye out for a response.
