05-31-2019 01:38 AM - edited 01-05-2022 07:38 AM
Activated two phones at dealer. One phone has mobile data, but no calling
The other has calling but no mobile data. Four people at dealer tried for 3 hours
no solution. Both phones are telus network compatible.
Sent private email, no reply so far. Any suggestions? Thanks
06-07-2019 12:50 PM
Thanks for your help. After 9 days, mods & London Drugs could not resolve.
Swiched to Koodo, put in sim cards, both phones worked great.
05-31-2019 06:57 AM
Please give more details.
- Which plan? Which phone model? New number or ported? whats working/not working?
| SIM 1 | SIM 2 | |
| Which plan? | ||
| Phone (brand, model) | ||
| Phone number (New or Ported) | ||
| Whats working/not working | Yes / No | Yes / No |
| SMS in | ||
| SMS out | ||
| MMS in | ||
| MMS out | ||
| Calls in | ||
| Calls out | ||
| Data access |
As others have said:
- If no data, did you setup APN?
- Did you try swapping SIM?
05-31-2019 01:47 AM
@Lakepuppy wrote:Activated two phones at dealer. One phone has mobile data, but no calling
The other has calling but no mobile data. Four people at dealer tried for 3 hoursno solution. Both phones are telus network compatible.
@Lakepuppy What happens when you swap sims between phones?
05-31-2019 01:43 AM
@Lakepuppy Have you correct the APN to PM network? Here is the link: https://www.publicmobile.ca/en/bc/get-help/articles?q=apn
05-31-2019 01:42 AM
What exact make/model are the phones?
Are they unlocked?
The data would be the following:
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
05-31-2019 01:42 AM
Both brand new numbers from public mobile or ported numbers from elsewhere? Porting can take a few hours to complete but sounds as though it may have been more than that now.
