Activate SIM
Ediza76
Hi
i had problem activating my husband's card..i tried so many times but failed...i don't know what's the problem
2 REPLIES 2
NDesai
@Ediza76 Try using incognito/private browsing mode or try another browser.
What error are you getting?
@Anonymous wrote:
Got 'er figgered? 🙂
OP entered the content under tag(s). I fixed it now.
 @NDesai below: Edit: Figured out the tagging. It's a setting. Turned it on and here we are. Thanks for clearing up the OP.
