Account locked
oliviali421
Hey,
I forgot my password unfortunately, my account was locked! Please help me out!
mimmo
@Brooke_C , @Dave_M People are asking on a daily basis on how to reset their passwords becasue the reset feature does not work.
Are you able to give some sort of update if/when you are going to fix the password reset feature.  It has been a very long time that it has been broken and brought to your attention more than once and yet nothing has been done.
Thanks
will13am
@oliviali421, the moderator team can be reached via private message using this link.  Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Taekgun
@oliviali421
You will need the assistance of the moderators to get you access to your self-serve account.  Send them a private message using this link: @CS_Agent, provide them with your name, account number and an explanation of the issue and they will be able to look into the matter for you.
