07-16-2018 10:59 PM - edited 01-05-2022 05:07 AM
I was just trying to log back in after being away from the country for extended period and found that I have just passed the time to reload credit, just wondering if there is any chance to reactivate my account with the number, cause I cant even go into my account now...
07-17-2018 02:11 PM
good luck, you may get lucky
07-16-2018 11:58 PM
If good old number, it is gone...
Anyway try and see if it still there.
07-16-2018 11:52 PM
ya... my number was a really good number... with only 3 different numeric # on it...
07-16-2018 11:51 PM
yap... actually I do need that lolll
07-16-2018 11:50 PM
There is a very small chance that your number is not yet taken. ![]()
07-16-2018 11:43 PM
@SD08 wrote:
@ShawnC13 wrote:
@mikado0401 wrote:I was just trying to log back in after being away from the country for extended period and found that I have just passed the time to reload credit, just wondering if there is any chance to reactivate my account with the number, cause I cant even go into my account now...
If it is past 90 days your account has been closed and your number is fine as well
I believe @ShawnC13 meant to say, if it is past 90 days your account has been closed and your number is lost as well.
Ya what he said is what I meant. Autocorrect on the phone it was supposed to be your number is gone.
07-16-2018 11:19 PM
Yes if it’s past 90 days your account will be closed and you will have to re-register. Will just have to send out a group message to your contacts. “hey I got a new number if you need to reach me” but make sure you just send it to the ones you like! It’s a good way to get rid of the ones you don’t 😆!
07-16-2018 11:12 PM
that's what I thought... guess it's time to get a new number then, thanks!
07-16-2018 11:11 PM
07-16-2018 11:00 PM
