11-10-2020 07:24 PM - edited 01-05-2022 05:25 PM
11-10-2020 09:06 PM
@fizzatif wrote:I am using public mobile no
905 xxx xxxx.
i need account no for my no.
thanks
Did you buy a sim and have a retailer activate it? There are 2 ways to create an account.
11-10-2020 08:10 PM
If you want to get your account number in order to port your number to another provider, you can get it from
1. your self-serve account or
2. the PM welcome email after you activation.
If you had enabled the autopay, it is better to create your self-serve account to remove your autopay credit/debit card info from your account before port out your PM number. Your account will be canceled after number ported out and you are no longer be able to login to your account again.
11-10-2020 08:03 PM
905 xxx xxxx.
thanks
Are you asking for your account number because you want to port out? That's usually the reason to want this. If there's any issue with the service, please feel free to ask questions and maybe things can be sorted out.
11-10-2020 07:29 PM - edited 11-10-2020 07:34 PM
11-10-2020 07:29 PM
905 xxx xxxx.
thanks
hi you need to activate a self serve account if you signed up online then you have one already
11-10-2020 07:27 PM - edited 11-10-2020 07:27 PM
@fizzatif I have edited out your personal info, please do not post it out in the public.
To get your account number, log in to your self-serve account and it is listed on the top right.
