Account Access
Shedunnit
I can’t get access to my account. The password reset is not working (no code sent to my email).
@Shedunnit
Have the 2FA code sent by text to your phone then clear your browser and login.
@Shedunnit
If having issues with your password, use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered.
If the account is currently in suspended status you can also look into obtaining a voucher to make a payment through 611,  see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
Locations to obtain some: https://publicmobile.ca/en/on/payment-voucher
You can submit a ticket here if issues logging in or to: Create or forgot My Account email or password link
RossN
@Shedunnit
hi if that won't work for you then you need to contact a customer service agent they will help reset your account
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
Timer
@Shedunnit
use browser from computer,/clear cache/cookies/use one page inPrivate mode,
or safari on private mode, then  Reset Password
after successful reset passowrd then close all browser,/clear cache/cookies/one page inPrivate mode,
To Login Page
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything, just wait about a 3 second will automatically be login,,
if want to contact PM support team by  > CS_Agent  to reset.
