08-06-2015 03:48 PM - edited 01-04-2022 12:41 PM
I have set up APN on my phone. I can receive pictures but I cant send pictures.
08-07-2015 09:15 AM
Welcome to Public Mobile and our vibrant Community, made with people who are eager to get you started with us!
For the current issue you are experiencing, have you followed the instructions on how to configure your APN settings?
If you have an iPhone the instructions can be found here: http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update-and-APN-settings/m-p/1610#...
If you have an Android device, the instructions can be found here:http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartph...
Let us know if this helps you? If it does, please mark this post as an accepted solution so others who have the same issue as you can find the correct answer to their problem.![]()
08-07-2015 01:40 AM
08-06-2015 07:36 PM
08-06-2015 05:05 PM
If APN settings MATCH, then try power cycle.
If that does NOT work, Reset the APN to default, and redo the APN again.
If issue is NOT resolved, EMAIL PM Immediately
08-06-2015 04:06 PM
Look under this:
APN (Access Point Name) and Tethering APN Protocol Set-Up Guide
in Ask a question.
The APN Settings will be displayed. You MUST ensure that all Info is 110% Exact
Otherwise, Data will Not Work, MMS Included
08-06-2015 04:01 PM
the carrier was Bell and I had my phone unlocked before going to public mobile. I have a Samsung phone
08-06-2015 03:59 PM
OK, lets see what the issue is. What is your handset model you're using. What Carrier was it with previously?
08-06-2015 03:58 PM
I signed up two weeks ago
08-06-2015 03:56 PM
Yes my data is on
08-06-2015 03:53 PM
Are you on the New PM Plan(s)?
OR the GF Plan from before Jan 27 of this year?
08-06-2015 03:52 PM
If your APN ( Access Point Name) is accurate, then only thing is, Did you switch your Data on? If Not, that's why. MMS requires that Data be enabled. Regular Text does NOT require Data to be turned on
